Avis Coupon & Discount Codes in US
Xray
Re: Avis Coupon & Discount Codes in US
Besides all these mentioned coupons someone has informations about Avis Discount Codes?
Thanks.
Thanks.
- Bentley
The Avis Discount Codes are called AWD. AWD is the abbreviation for Avis Worldwide Discount. An Avis AWD number is used to save on a rental car booking at Avis.
You must also know that all Avis car rental discount codes either coupon codes or AWD numbers must be applied at the beginning of any booking process at Avis. An application at the end of the booking process is no more possible.
- Bentley
In the following I can provide you with a list of AWD numbers or AWD codes:
- you can get 10% off the base rate on a monthly car rental: AWD Code A538100
- you can get up to 25% off base rate with 10% donated to Susan G. Komen: AWD Code A349300
- you can get up to 25% off base rate with 5% donated to Make a Wish: AWD Code H749900
- you can get as an AARP member up to 30% off base rate: AWD Code A359807
- you can get 25% off base rate as a veteran or military family: AWD Code T765700
- Van08
Any one has already used the AWD Code A359807 for AARP members? Does you really save up to 30% off the base rate?
- Ferrarifan
- Horsepower
Just read that the Coupon MUWA146 is still valid through 5/31/2020. With this coupon customer gets $10 off when $100 are spent.
- Bentley
